Ferrari's latest F1 launch
Written by Wil Harris
January 26, 2006 | 13:17
Tags: #antonio-calabrese #dual-core #formula-1 #opteron #processors
Companies: #amd #ferrari
The AMD-Ferrari collaboration
Many of you will already be aware of the collaboration between AMD and the Ferrari Formula 1 team - indeed, we've written about it in these very pages previously. Simply put, AMD is far more than just another name on the car: AMD contributes in very real terms to the success of the Ferrari team.
Ferrari has deployed AMD processors and technology throughout its enterprise. That ranges from staff using Turion laptops to check their email, through to massive 400-node Opteron clusters used for modelling fluid dynamics in the wind tunnel. With such a big-name, glamorous sport to be associated with, AMD is keen to make sure people know about the cutting edge work it is doing with Ferrari - because it's interesting as well as effective. To that end, we went off to Mugello racetrack, just outside Florence in Italy, for the official unveiling of Ferrari's new F1 car and to chat to the technicians there about their work with AMD.
In this article, we're going to take a look at the work AMD is doing, talk to Ferrari, and then treat you to some hi-res eye-candy of some very nice cars at the end.
If you're a motorsport fan, you'll be aware that Ferrari didn't do quite as well last year as it intended to. This new season is a clean slate, with an entirely new car and a new engine. Due to regulation changes, the car is now only a V8 as opposed to last season's V10. The aerodynamics have been completely reworked to accommodate this. Still present as number one driver is Michael Schumacher, and joining him this season is Felipe Massa, the talented young Brazillian. Both are hoping to see Ferrari return to form and dominate the season as they have done previously.
Ferrari's latest F1 launch Ferrari 248 F1 car Ferrari's latest F1 launch Ferrari 248 F1 car
Left - The Ferrari team poses with the new car: R-L is Jean Todt, Michael Schumacher, Felipe Massa, Luca Badoer, Mr Ferrari, Luca di Montezemelo, engine technicians. Right - Schumacher takes questions from the press.
The role of the Opteron
Crucial to the team's success is the Opteron processor. Why? Because so much of the car's design and engineering relies on high-powered computing systems. AMD is being used for:
  • Telemetry: During every race and practice session, data from the onboard computers are sent back from the car to the pit garage. This data needs to be crunched and analysed very quickly so that the engineers can extract race-defining information. Pit stop strategies, tyre decisions and fuel loads are all based on computer simulations of the race extrapolated from telemetry data.
  • Car design: The precision required to design every millimetre of the car obviously requires a high-powered CAD/CAM programme running on a meaty workstation.
  • Wind tunnel: Crucial to the speed of the car is the aerodynamics of the wings and the body shape. To test this, the team uses a wind tunnel and then records how the air flows over the car. By recording the airflow, they can work out how to make the car sleeker. This data recording is called Computational Fluid Dynamics, or CFD for short.
AMD is involved in all these areas. Opteron machines populate the pit garage, and AMD's pair of technicians are always visible hunched over machines on race day. When it comes to design, Opteron-based workstations run the sophisticated software required. Wind tunnel data is analysed in a new state of the art facility built especially for the purpose, populated with a mammoth 400-node cluster of dual-core Opteron machines.
The software running in the data centre is called Fluent, which is the leader in CFD analysis. With the help of AMD, it's been written to take advantage of the extra memory allowed by the 64-bit processors that AMD has. AMD has also been able to significantly up Ferrari's computing performance over the last year. Just as many of you will have upgraded to a dual core AMD processor, merely flashing the BIOS to enable the extra functionality, Ferrari has done exactly the same thing - times 400. Because Fluent is a threaded application from the ground up, dropping in effectively another 400 processors literally doubles performance. That's a pretty cool real world application of the technology.
